Applying a data visualization
The Data Visualization menu on the View bar lists the data visualizations available in the current file, in user and workgroup folders, and in Vectorworks libraries. Currently applied visualizations display with a check mark. The Enable Data Visualization toggle turns the selected visualizations on or off.
The Data Visualization menu is only available when a design layer is the active layer; on sheet layers, data visualizations are applied as viewport properties.
To apply a data visualization to the drawing:
Click the Data Visualization menu on the View bar.
Select the data visualizations to apply; if needed, enter text in the search box to filter the list.
The icon to the left of a visualization name indicates whether the the visualization changes object attributes or hides objects
Selected visualizations display with a check mark, and a number next to the visualization indicates its priority. If there is a conflict, the visualization with the lower number takes precedence. Deselect all visualizations to display the drawing with normal object attributes and visibilities.
When closed, the top of the menu displays the selected visualization name, or it indicates that multiple visualizations or no visualizations are selected.
Click Enable Data Visualization to toggle the selected visualizations on or off. When the toggle is off, the menu displays with <None> and all visualizations are deselected; however, the previously selected visualization status is remembered. If you toggle the visualizations back on, previously selected visualizations are selected and applied again.
The toggle button indicates the status of the data visualization feature:
Disabled: No data visualizations are selected, and the data visualization feature is off. Select a data visualization to turn on the feature.
Run: Data visualizations are selected, and the data visualization feature is on (your highlight color may be different). The drawing displays with the selected data visualization settings.
Pause: Data visualizations are selected, but the data visualization feature is paused, so the drawing displays with object attributes. Click the toggle to apply the selected data visualizations again.
In Spotlight, data visualizations apply to lighting device geometry without affecting the label legend. To set the label legend attributes, see Creating label legends.
Applying a data visualization to a viewport
Data visualizations can be applied to a viewport on a sheet layer. Data visualizations take precedence over class viewport overrides; if there is no conflict between class overrides and data visualization settings, the class overrides display, but if there is a conflict, the data visualization settings are used instead. Data visualizations prevent layer viewport overrides from displaying. Turn off data visualizations in a viewport to display the override settings.
Advanced viewport settings for Black and white only and Use layer colors do not apply when a data visualization other than <None> is selected for the viewport.
To apply a data visualization to a sheet layer viewport:
Do one of the following:
For an existing, selected viewport, select the data visualization to apply from Data Visualization on the Object Info palette.
If the viewport has not yet been created, select the data visualization from the View bar before creating the viewport. The current data visualization automatically applies to the viewport.
For a viewport style, select the data visualization to apply from the Viewport Style dialog box, and set the selection to be by style or by instance for viewports that use the style.
Select multiple data visualizations, if desired. Select data visualizations that do not conflict with each other.
A data visualization legend is automatically added to the sheet layer.
Data visualization legends
When a data visualization is assigned to a sheet layer viewport, a legend is automatically created within the annotation layer of the viewport. If multiple visualizations are selected for the viewport, a legend is created for each visualization.
To edit the legend properties:
Right-click on the viewport and select Edit Annotations from the context menu.
Select the legend to view and edit its properties in the Object Info palette. Measurements are in page units.
Parameter |
Description |
Title |
The legend is named after the data visualization by default; enter new label text to change it |
Swatch Coloring |
Select the combination of background and foreground fill and pen for the color swatches; only available for visualizations that change object attributes |
Swatch Width/Height |
Specifies the color swatch width and height; only available for visualizations that change object attributes |
Overall Width |
Specifies the overall legend width |
Note Text Indent |
Sets the distance to indent the label text; only available for visualizations that change object attributes |
Line Spacing |
Sets the spacing of each line in the legend |
# of Columns |
Sets the number of columns, up to four |
Gutter Width |
When more than one column is selected, sets the distance between the columns |
Break Note Text Across Columns |
When more than one column is selected, allows text to break across columns; when deselected, text for each note does not break to the next column |
Text Alignment |
Specifies the alignment of the note text |
Edit Labels |
Opens the Data Visualization Legend Labels dialog box, for reordering labels and changing label text |
Format Title Text |
Opens the Format Text dialog box; see Formatting text |
Format Label Text |
To edit or reorder the legend's labels, click Edit Labels.
The Data Visualization Legend Labels dialog box opens.
On the left, the extracted values display. Click on a value and drag within the column to change the order of the labels. To change the label text, click on a label and enter the new name. Click OK to return to the Object Info palette.
To delete a legend, select it and press the Delete key. This is useful when more than one viewport on the sheet layer shares the same data visualization, and only one legend is necessary, or when a legend is not desired.
If a legend is accidentally deleted, create a new one from the annotation space of the viewport. Right-click on the drawing and select Create Data Visualization Legend from the context menu.
